Results 1 to 10 of 12
- Jul 2007
- 4
October 10th, 2007 01:59 AM #1tok sound sa manibel occurs when:
1. kapag dumadaan ako sa humps, (yung pagbaba pero minsan wala)
2. when turning left/right, pagbalik ng steering may tok sound (minsan wala)
3. kapag nag-brake ako may tok sound din
** 2 yrs. and 7 mos. plang adventure ko, dati mahina lang pro prang lumalakas n sya, nakapagpalit na ako ng lower ball joint at upper pero meron pa din, nag pa lube na din ako,pinahigpitan ko din lahat ng pang ilalim ko...
but still gnun pa din... lahat daw ng pang ilalim ko ayos pa...
I hope matulungan nyo ko... matagal ko na problema 2...
salamat po sa magreply...
Tsikot Member Rank 5
- Nov 2003
- 3,848
October 10th, 2007 08:11 AM #3i doubt cv joint yan. either stablink or shock mount siguro assuming all the supports are ok pa.
October 11th, 2007 01:28 AM #4
i have this same tok sound but its not from the manibela but from the front tire driver side, everytime na kakabig ako to my left eh "TOK!" ang naririnig ko, tapos recently i have this "ugong" sound when my speed comes up to around 60-80 kph, this ugong ingay is somewhat not that noisy/loud but very "vibrative" kung baga, yung ugong ramdam sa dibdib yung vibrating sound... pero pag mabagal mga up to 40kph walang wala yun nga lang kakabig ako pa left at may tok! sound naman... what do you think it is???
- Sep 2007
- 215
October 11th, 2007 10:49 PM #5basta pag turning tapos may tok sound yan check mo yung velocity joint mo (c.v. joint mo) sira na yan
pag straight lakad mo tapos tok my lubak or tok even road naman yung stab links yan or stab bushing
pag tok niya ay malakas shock mounting or shock absorber na yan
ugong sound when wheel bearing ...
BANAWE AUTO SUPPLY
7120115
regy
October 11th, 2007 11:57 PM #6
Sir ganyan din ang napansin ko sa adventure ko .. go to mitsubishi adventure forum marami tayong katulad na ganyang case .. flaw na raw ng adventure yun as per casa . swerte ka nga almost 3 yrs na sa yo .. sa kin 5 months pa lang may tok na... hope it helps ..
- Sep 2006
- 47
October 12th, 2007 05:15 AM #7I also experienced this "TOK" when turning left or right. I brought it to speedyfix and it was just a loose thread somewhere near my stabilizer link.
- Nov 2003
- 3,848
- Jul 2007
- 4
October 16th, 2007 04:07 AM #9thanks sa mga nagreply, will try to check sa cv joint and dun sa iba pang suggestions... will giv feedback kapag napa check ko na..
again thank u po!
- Sep 2007
- 26
October 31st, 2007 07:56 AM #10Sir,
Sir pa ride sa thread mo, un advanture ko matic meron din "tok" minsan pag slight turn tapos recently during parking, may tok pag reverse then brake pero pag drive wala naman. pina park ko sa father ko then pinkingan ko, sa front side di ko lang sure kung san part pero during reverse and braking lang? Ano kaya problem and san maganda shop pa check around laguna or manila (weekends)? Thanks
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
