Results 1 to 10 of 12
Tsikot Member Rank 5
- Nov 2003
- 3,848
October 10th, 2007 08:11 AM #2i doubt cv joint yan. either stablink or shock mount siguro assuming all the supports are ok pa.
October 11th, 2007 01:28 AM #3
i have this same tok sound but its not from the manibela but from the front tire driver side, everytime na kakabig ako to my left eh "TOK!" ang naririnig ko, tapos recently i have this "ugong" sound when my speed comes up to around 60-80 kph, this ugong ingay is somewhat not that noisy/loud but very "vibrative" kung baga, yung ugong ramdam sa dibdib yung vibrating sound... pero pag mabagal mga up to 40kph walang wala yun nga lang kakabig ako pa left at may tok! sound naman... what do you think it is???
- Sep 2007
- 215
October 11th, 2007 10:49 PM #4basta pag turning tapos may tok sound yan check mo yung velocity joint mo (c.v. joint mo) sira na yan
pag straight lakad mo tapos tok my lubak or tok even road naman yung stab links yan or stab bushing
pag tok niya ay malakas shock mounting or shock absorber na yan
ugong sound when wheel bearing ...
BANAWE AUTO SUPPLY
7120115
regy
October 11th, 2007 11:57 PM #5
Sir ganyan din ang napansin ko sa adventure ko .. go to mitsubishi adventure forum marami tayong katulad na ganyang case .. flaw na raw ng adventure yun as per casa . swerte ka nga almost 3 yrs na sa yo .. sa kin 5 months pa lang may tok na... hope it helps ..
- Sep 2006
- 47
October 12th, 2007 05:15 AM #6I also experienced this "TOK" when turning left or right. I brought it to speedyfix and it was just a loose thread somewhere near my stabilizer link.
- Nov 2003
- 3,848
- Jun 2007
- 40
October 31st, 2007 08:07 AM #8ganyan ren problema ng car na nabili ko d2 sa isang tsikot member, walang "tok" sound pero gya ng nangyari, nabaklas ang cv joint ko as in talagang natangal habang papaliko ako , both cv joint, boot at suspension nasira, pinalitan lahat!, peor yung vibration na parang coming from the front. opposite ng driver meron vibration sound kung bumibilis na, i still dont know what caused it. help!!
Last edited by ghosthunter; October 31st, 2007 at 08:39 AM. Reason: Change an "all upper case message" to lower case
At the expense of rear cargo space. The floor is raised around 8inches for the batteries.
2021 Toyota Land Cruiser LC300
