ano ano b ang pwedeng idamay n mga parts kpg meron kng worn out n piston ring
Cylinder wall,the engine will have low compression, lots of blowby and will burn oil.
Let start with Cylinder wall (liner for Diesel) if your lucky. If your unlucky include piston rod, crankshaft, all main bearing, one of the cylinder head (if V6). If that happen, might as well buy a new/used engine.
madami bro kaya wag kana mag antay baka mag engine lock pa yan .. pag engine lock na ahhh prepare mo wallet mo..
engine oil will get dirty faster due to incomplete sealing of the combustion chamber.
