Results 1 to 4 of 4
    Jun 2010
    My car won't start because of this, what should i do?
    kaya ng locksmith yan
    Quote Originally Posted by paulnikolo View Post
    What is the make and model of your vehicle? You may try and call the casa and ask for assistance regarding this matter. Since your car is not drivable, they may send someone to assist you. Or they may refer a good locksmith that is accredited with their company.
    Feb 2009
    the last time i pulled a broken key out of the ignition switch, i improvised a haemostatic locking pliers that i filed the clamping ends to about 3/32 of an inch (the usual thickness of older keys). if you want to do this yourself, you can purchase this tool from your local medical supplies store. what you have to do is file down on the end that goes into the keyhole. once you attain the right thickness, it can go into the broken key and pull it just like pulling gray hair with very little resistance. good luck!
help!broken tip of the key left in the ignition switch!
