Results 1 to 7 of 7
- Sep 2005
- 29
February 4th, 2008 12:04 AM #1Two months ago, there was a leak of brake fluid between the master cylinder and the vacuum booster (hydrovac as what the mechanic calls it) so it was fixed by means of a repair kit. Ngayon, ito at bumalik na naman. Ano kaya ang mas dapat ba na gagawin? Any advice would be much appreciated.
February 4th, 2008 06:46 PM #2
wag na repair kit. palitan na yun part ng original.
tanggal agad sakit ng ulo mo.
Tsikot Member Rank 5
- Nov 2003
- 3,848
- Nov 2003
- 3,848
February 13th, 2008 10:56 AM #6yup, bleed muna and if does not work then malamang internal leak sa brake master.
February 13th, 2008 12:55 PM #7
+1 po ako sa replacement ng assembly. twice ako bumili ng repair kit kasi baka daw di maganda ung una pero ganun pa rin. sayang lang pera sa repair kit. ganun din sa clutch master, dapat buo na.
have you tried spraying peppermint?
How to get rid of kittens in the engine bay
