Results 1 to 7 of 7
    Aug 2010
    Nagtataka ako tuwing mag brake ako hihina speaker ko then pag andar na lalakas ulit aw ano kaya possible problem neto?
    Check if your battery terminals have good connection.
    Check if your battery is still good or failing.
    Check if your alternator is still giving proper current or needs fixing or replacement.
    Aug 2010
    Sir ok naman lahat ng sinabi niyo pinatest ko yan kanina yun nga lang bagong kabit yung grounding kit ko...
    Jul 2010
    alternator yan
    Aug 2010
    Last month lang po ako nag palit ng brand new alternator and sabi sakin nung pina check ko alternator kumakarga naman ng maayos.. hmm baka my naiipit lang dun sa speaker pag nag brake ako possible kaya yun?
    Did the problem occur right after you attached the grounding kit? If so, remove it and then observe. Maybe there is something wrong with the installation.
Weird Problem: humihina Speaker ko while im braking
