Results 1 to 10 of 19
- 11
November 12th, 2002 04:27 PM #1I got a big yellow illegal parking sticker from my dear school because I brought a car that doesnt have our gate pass sticker. The former are very notorious owing to the fact that they dont come off that easily. How can I remove them???
November 12th, 2002 04:49 PM #2
mojo_08, i assume your from ateneo :wink: madali lang yan bro....maligamgam na tubig lang katapan nyan. buhusan mo habang kinukutkot ko ng fingernails mo. hth :mrgreen:
November 12th, 2002 05:33 PM #3
Where is it stuck to?... the glass part or to a painted part of the car?
if glass part, using a razor blade will help to clean off the sticker.
if painted part, you might need to buy an adhesive removed solution from a hardware store. Also "Wipe Out" might help too.
- 37
November 12th, 2002 06:14 PM #4sinasabon ko muna yung sticker pag nasa glass. tulad ng lto stickers, masyado madikit. gamit ko yung regular cutters. pero ingat kasi since may sabon sya, madulas yung blades. make sure din na pa slant yung strokes dahil baka magasgas yung glass. it works for me. sana makatulong
November 12th, 2002 07:53 PM #5mojo_08, i assume your from ateneo madali lang yan bro....maligamgam na tubig lang katapan nyan. buhusan mo habang kinukutkot ko ng fingernails mo. hth
- 11
November 12th, 2002 08:57 PM #6i assume your from ateneo
thanks all for the advice!
ginamitan na lang nmen ng knife pero may natira pren na onting adhesive.
from there cguro madali na tanggalin.
from now on, magdadala na ako ng kutsilyo pag dala ko oto ng dad ko!:mrgreen:
November 12th, 2002 11:40 PM #7
yung konting adhesive pwede mo spary ng WD40. Let it soak tapos ayun dali na tanggal yun.
- 19
- 106
November 13th, 2002 03:14 PM #9correct sila, tapalan mo muna ng basahan na may hot water or heat it with a hair dryer para malusaw yun adhesive
November 13th, 2002 03:58 PM #10
sayang at natanggal mo na pala yung sticker sa oto mo. pero para sa magkakaron ng ganitong problema sa susunod, ang usually ginagawa ko e pumupunta ako dun sa lugar kung saan ako nagpapa-tint (o kung saan man kayo nagpapa-tint). tapos papatanggal ko na lang sa kanila gamit yung paleta nila (meron silang paleta na made of plastic kaya hindi nakakagasgas ng glass). ayun solb na! bigay lang ako ng P5 or P10 masaya na sila :D
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
