your cv joint either needs to be re-packed or replaced or may nasagasaan kang nagtitinda ng sigarilyo (takatak boy) at nandyaan pa sa ilalim ng auto mo.
Pa-check mo na yung cv joint ng car mo, kung kailangang palitan, palitan mo na agad kse pag bumigay na yung cv joint ng oto mo, hindi ka na aandar, literally.
Pa-check mo rin yung axel boot mo. Yung yung rubber sa ilalim ng naka-connect sa gulong mo. I recently had mine replaced, all four of them, inner and outer. Pag nabutas kasi yon naghaharden or totally nauubos na yung molicote grease. And ang masama dun, pagpinabayaan mo lang at masira, buong axel papalitan mo. Axel boots costs are P400++ each and yung molicote grease P75++.
the price of the CV joint depends on the car. usually once umingay na sya... even if it is repacked di na mawawala ng tuluyan yung noise kaya better to replace it na
pass by the shop if you like or tawag ka at 7237625 to as for a quote... thanks!
have you checked your power steering fluid? before you replace your CV joint, check mo muna baka wala lang laman sa reservoir. otherwise, palit ka na ng CV joint.
1. Kapag ba naka-hinto ang kotse, tapos kinabig yung steering ng todo pakaliwa at may tak-tak-tak (or tok-tok-tok) sound, CV joint pa din ba yun?
2. Paano kung tuwing kinakabig lang may tak-tak-tak, pero once naka-kabig na at tumatakbo nang paliko yung kotse eh wala nang tunog, CV joint pa din ba yun?
3. Paano kung tuwing kinakabig lang may tak-tak-tak, pero pag umaandar (whether paliko or diretso) eh walang tunog, CV joint pa din ba yun?
pa check mo rin ball joint mo sa right side. i had the same experience din, found out na ball joint instead of the cv joint. yun cv joint alam ko maingay na"tak-tak-tak" pag full turn. pag konting turn sa left meron na ingay, baka ball joint sa right.
D Balljoint and CV joint ar not d same thing. Pag me clicking tuwing lumiko AT under application of engine power(aka accelerating), CV Joint na nga yun. Pero pag ikay lumiko at parang bumagsak yung harapan PAGKA-FULL TURN mo sa manibela, AT maganit ibalik, ball joint ang me kagagawan nun.
Originally posted by ebbfolls D Balljoint and CV joint ar not d same thing. Pag me clicking tuwing lumiko AT under application of engine power(aka accelerating), CV Joint na nga yun. Pero pag ikay lumiko at parang bumagsak yung harapan PAGKA-FULL TURN mo sa manibela, AT maganit ibalik, ball joint ang me kagagawan nun.
pre ang problem kasi sakin ganito... pag turning left ako and kahit konti lang around 30-45 degrees turn, meron akong naririnig na "tak-tak-tak" habang naka accelerate ako. Pero nawawala yun sound pag ndi ako nagaacelerate or binitawan ko gas pedal.
pinacheck ko ito sabi hindi daw cv joint... sabi nila ball joint daw. I had it replaced since meron pa ako spare na used orig nun. for a week nawala yun sound pero ngayon meron ulit.... dunno kung ano b talaga problem nun.
