Results 11 to 15 of 15
November 4th, 2006 12:09 AM #11
may study ba na isinagawa kung how much improvement sa power output after installing this kind of spark plug?
November 4th, 2006 12:41 AM #12
i tried using splitfire last feb 2004.. didn't notice any gain in power or fuel efficiency though.. got it back then for 1.4k (4 pcs).
2.5 years and 48k kms after, yun pa din ang nakakabit sa ride ko. checked the plugs last pms and maganda pa din sunog...
November 6th, 2006 11:11 AM #13
The gains for platinum/iridium plugs mostly reside in the fact that they last longer and provide consistent spark for a long time.
You can gain a lot of horsepower from the right plugs (maybe 3-4 hp on our small engines), BUT:
- most people don't test them scientifically, as, consider that a dyno test costs a lot (2,500 pesos for a decent one), so it's not worth anyone's time to do ten or twenty tests just to find the right plug.
- then again, some people do take the time, and in the case of some cars, stock plugs or the platinum version of the stock plugs actually give more power.
- and finally, there's no "one size fits all" performance plug. Different cars have different combustion chamber designs, so what's total crap on one car (Splitfires on Sentras) might be pure gold on another.
If you're lucky, there's a dyno test of your particular car online showing which spark plugs give the best performance, but don't count on it. Most tuners who test have highly modified or already powerful cars, tests like on Sentra.net's Kojima's Garage for cheap cars like ours are few and far between.
But you never know. Search for your particular car on the web, read through enthusiast forums, and absorb what you read. You just might find a clue to the perfect plug hidden in one of the thousands of pages on your car on the web.
November 6th, 2006 09:22 PM #14
waste of money. nag splitfire din ako dati pati high tension wire, wala namang gain in hatak or fuel economy as promised, maganda lang tingnan pagbukas ng engine hood mo yung high tension wire.
November 6th, 2006 09:29 PM #15
Have been using this eversince after 5,000Kms now the car is already 65,000 and is still installed... never ko din tiningnan hehehe. So ang tune up ko is change oil lang.
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
