Results 1 to 12 of 12
    Sep 2006
    question po ulit!
    yung tacho and speedometer ko ay minsan hindi gumagana.. sinusumpong.. mei alam po ba kaung nagrerevive netong mga stock meters na to?
    thanks po!
    cheers!!!
    what's your car?
    Aug 2006
    how old is your car? check the sensors...
    ang dami atang may problem sa speedo/odo ngayon ah....
    * HG, baka nilusong sa baha?
    Sep 2006
    my car is a lancer boxtype GSR 1980's.. almost 20+ years running.. sabi nung nakausap ko, cable type p daw yung tacho ko and hindi ko na alam yung sa speedo... nkakailang kasing patay minsan yung tacho speedo, o kaya yung speedo lng gumagana.. dukhang dukha... T_T aun po.. sana may narepair pa nung ganun o kaya iconvert yung stock tacho and speedo using new mechanism that is used on todays tachos.. ayaw q kasing bumili ng tacho na yung common na kinakabit ngayon.. kasi ooccupy ng space tska prang sagwa dahil mei tacho akong orig tas ganun.. pwera sana kung yung dashboard ko is LANCER SL.. wala kasing tacho ang SL.. speedo lng..
    nkakasira ren po ba ng meters yung pag lusong sa baha ng car?
    thanks po!!!
    cheers!!!
    Quote Originally Posted by legnacilyz View Post
    thanks po!!!
    cheers!!!
    iba mechanismo nyan. more on the mechanical type sya, compared to the semi-electronic speedos of todays cars.
    kung sira na yung sa iyo, hanap ka na lang ng surplus. dami nyan....
    Sep 2006
    thanks po! san po ba ang recommended niyong mapagbibilhan ng surplus na tachos/speedo ng ganitong type ng kotse?
    cheers!!!
    cheers!!!
    dami kong nakikitang ganyan sa banawe pre. almost all surplus shops there have that.
    Sep 2006
    hmmm.. I SHOULD ReALLY MUST PAY BANAWE A VISIT! eehhehe thanks po sa mga reply sir!!!
    cable type na tacho? hmmm...yun cable ng speedo mo baka maluwag lang. sa tranny usually connected yan. yun tacho sa distributor naka connect, pero most probably wire yan and not cable.
    Sep 2006
    thanks for the replies! about sa speedo koh.. uhh.. sa mechanic ko na lang paayos.. yung tacho, mejo reach ko pa naman eh.. pag binuksan ko yung distributor, ano hahanapin ko para ma-identify ko yung wire ng tacho?? what does it look like? and pag nahanap ko, ano ichcheck ko?
    thanks!!
    cheers!!
Question po ulit! about sa Tacho/Speedometer nman po!
