Results 1 to 9 of 9
August 18th, 2006 12:27 PM #1
Good day mga sir.
my 92 sentra just had her new Automatic Transmission installed yesterday.
while test driving it, napansin ko hindi gumagana ung speedometer.
any comment on what could be wrong with my car?
TIA!
August 18th, 2006 12:41 PM #2
August 18th, 2006 02:12 PM #3
Yup, baka nga speedometer cable lang.
But its important to have it checked asap, kasi from what I know, the shifting points of the tranny will be dependent signals provided by the speedo and tachometer
August 18th, 2006 05:32 PM #4
Check the connection, and check whether the people who did the job used your old speed sensor (just follow the wire down to the transmission behind the engine to find it) or used the one attached to the new transmission. Might be better to just put your old sensor back in.
August 19th, 2006 09:50 PM #5
August 19th, 2006 11:02 PM #6
The speedo cable should be the culprit. Check if both ends are connected properly. I had the same problem after having a shiftlight installed.
August 20th, 2006 09:05 AM #7
Yup, cable yan malamang, akin lagi ngang nagtitwist diko alam kung bakit, kaya pag di na pumipitik speedo ko, yun na ang problema.
August 22nd, 2006 09:31 AM #9
Thank you very much mga sir sa mga reply!
ok n ung speedometer ko.putol pala ung cable kaya ayaw gumana.
How about 97 LXi?
Civic horsepower
