Results 1 to 6 of 6
    Jun 2004
    Does anyone know the size of the oil pan drain bolt for a 1983 Ford Telstar (Mazda 626)?
    The head of the bolt is rounded due to multiple tries over the years trying to remove the bolt using incorrect tools.
    This is what the car looks like:
    Jun 2005
    just a suggestion. on your next oil change, remove the bolt, go to the nearest auto supply. meron sila nyan. or kung wala na yung lumang bolt mo, just tell them na pang oil pan ng telstar
    Jun 2004
    Problem kasi nung last oil change walang available na bolt dun sa malalapit na auto supply, balak ko sana pumunta sa pasay para bumili ng part.
    Jun 2005
    mas maganda pa din kasi sir kung may dala kang sample kung pupunta ka sa autosupply.... suggestion ko lang naman.... or, kung may malapit sa inyo na bolt and nuts na tindahan, dun mas malaki chance meron dun. hth
    Jun 2005
    Maybe the oil plug is standard size.
    Jun 2005
    By the way, I've check the computer in the shop with '83 Mazda 626, and here is the size of the plug that they used.
    Type : Standard
    Thread Size : M14-1.50
    Under-Head Length : 10.10mm
    Head Size : 17mm
    Head Style : Flanged Hex
oil pan drain bolt size
