when you turned off the car key na and still the engine runs for a few seconds at may "kilig" effect. ano kaya remedyo dito and what causes this? ganito kasi nangyayari sa lancer singkit ko.
or could simply be carbon deposits in the cylinder head taht becomes very hot and acts as an ignition source. kahit walang spark from the plugs andar pa rin engine for some time kasi this carbon deposit acts like a glow plug.
to clean your cylinder head, pistons, valves and exhaust of these carbon deposits, take the following steps.
1. go to the skyway, get card.
2. floor gas pedal all the way until engine rpm reaches the red line. keep doing this in all the gears. select the gear that keeps your engine at or near the red line at desired vehicle speed.
3. surrender card at toll gate, pay toll.
your car had just experienced a ferrari tune up, all carbon deposits are now gone. do as often as required.
note that there is only one instruction in between 1 and 3. so don't do anything else. failure to do so will result in unsatisfactory engine performance.
nice one yebo ...ganda talaga andar ng makina after bumiyahe...tanggal lahat ng carbon deposits
kung di maibyahe, pwede rin naman magpa-Carbon Clean meron nito sila Doc Diesel at Caltex sa E. Rod...
sir zero, have your car's ignition timing checked before doing anything else...kung malapit lang po kayo sa amin(Manila area) check natin iyan then adjust kung kailangan...no charge
yung friend ko naman dati experienced the same problem with her Toyota (AE92)...maluwag lang pala yung mga belts...
Sir Yebo, nung bago modify yung engine ko sinubukan ko yun. Sabi sakin nung gumawa, break-in ko muna. Di pala yun yung ibig sabihin ng break in. ayun makina ko broken. haha 2 overhauls in a span of 2 weeks. hehehe
