Results 1 to 10 of 12
- Oct 2006
- 30
October 9th, 2006 04:18 PM #1Mga sir,
Sensya na po.. just new here... help naman po. I have this civic a/t, meron po kc akong irritating sound na naririnig sa car ko after na pinagawa ko yung compressor... hindi ko po alam kung compressor ang problem or something else coz even naka off yung compressor... naririnig ko parin sya... pinalitan po kasi yung bearing sa labas ng compressor. dinala ko na po sa autoshop, sabi belt daw... pinapalitan ko lahat ng belt ganon parin pati yung bearing ng idler pulley... is it possible po ba na ang culprit ay yung compressor even naka off po yung aircon. Sensya na, I'm a lady driver kaya wala ako masyadong alam sa engine.
thanks
October 9th, 2006 04:23 PM #2
October 9th, 2006 04:32 PM #3
Anong klaseng ingay po ba yung naririnig nyo? Squeaking sound ba? Kung ganun baka sliding belt lang.
Try this din, kung nasa shop ka, patanggal mo yung belt ng A/C then start the engine. Kung wala na yung sound, most probably sa A/C system nga ang problem pero kung nandun padin, you might want to check na yung bearing ng alternator. and any other moving parts while the engine is idling (minor).
HTH.
P.S. I'm glad I was able to help sa pag post mo ng new thread. Welcome din sa tsikot.
- Oct 2006
- 30
- Oct 2006
- 30
October 9th, 2006 04:46 PM #7sqeaking sound nga po... so meaning po even naka off yung aircon may kinalaman parin yung compressor.. kc po pina back job ko yung repair ng compressor sabi ko bigla na lang nagkaroon ng ganong sound after na marepair ang compressor ang sabi naman po nila.. di daw po kc naka off naman yung aircon... might be sa engine daw...pinatingin ko naman sa shop wala naman daw problem sa engine.
- Oct 2006
- 30
October 9th, 2006 04:59 PM #8correction po.. di po pala sqeaking sound... di ko po madescribe parang grinding sound na di ko malaman kung ano.. basta dinig po yun pag idling yung car.
October 9th, 2006 05:04 PM #9
Hmmm... It can be a faulty power steering bearing or belt too. Kung grinding sound, hindi nga belt yun. Mukang naghuhugas kamay lang yung A/C shop na napuntahan nyo and don't want to accept the fault.
Most probably, bearings lang ang may tama dyan.
Teka, baka naman yung auxillary fan lang ang may tama. :idea:
- Oct 2006
- 30
October 9th, 2006 05:11 PM #10Ganon po ba... so ano ano po yung possible reasons na pwede kong ipa check... dadalhin ko po ulit sa auto shop... kaya na po ba auto shop dito or need ko po dalhin sa honda mismo. is this a minor problem lang po ba..tnx.
high idle RPM at engine start
