Results 1 to 7 of 7
- Mar 2007
- 26
January 15th, 2008 12:47 PM #1nu sa tingin nyo problema pgngdidim ilaw saw dashboard tsaka orasan ?pinalinis ko n grounding and battery terminals.tpos ok nman karga ng batterya.napapansin ko cia pag gabi lalo n pgon n lahat accessories like headlight, aircon, sounds.may isang beses p n namatayan ako makina.alternator kaya to?pagtumatakbo ako nsa 13.5 to 13.9 nman reading ng voltmeter ko.any suggestion.
January 15th, 2008 12:58 PM #2
pang start lang ang battery, pag naka on na yung engine, alternator na nagsusuply ng power sa kotse kaya malamang alternator na yan.
pero its always best to have it tested first before you start buying parts...
January 15th, 2008 12:58 PM #3
Had experienced it also before, tumirik nga ako sa daan. Unti unting dumilim ang ilaw, umuulan pa nun, pinatay ko aircon at stereo praying na umabot pa ako sa amin, di pa rin. Di na raw bumibigay ng kuryente ang alternator, kaya tumirik ako. Have it checked by a qualified electrician, if it turns out na alternator, going rate nito ngayon is aroud P3k to P5k depende kung replacement or surplus. Have your battery checked and grounds re-checked also.
January 16th, 2008 03:40 AM #4
Do you have stereo system and amp? If you do....
This is what Im saying all along from other thread that before building a system must know if your car can handle the demands of a multi amp system.
Let me explain why?
Your car electrical system(car only) is designed to do one thing: Supply the car diff. components like headlights, air conditioner, brake lights,doom lights, signal lights, etc with needed current and voltage to operate properly.
Kung ang kotse mo ay gawang Japan most Honda or Toyota have alternator rated for 35 ampere. Tama lang na i-support niya ng 125 watts in amplifier power. Most german car have charging system rated up to 90 ampere at sufficient to push up to 500 watts in amplifier power.
Kaya kukurap-kurap ang ilaw mo dahil hindi kayang supplyan ang alternator mo ang buong system mo dahil sa mga extra na load. On the other hand, you are asking for trouble if you keep the volume cranked up dahil kapag ang system mo ay nag-demand ng current more than alternator can supply, it ca grab current from your battery up to point .....titirik ka.
Kaya kung gusto mo ng power na nakakagising ng mga patay, you have to rebuilt your alternator into higher output o kaya palitan mo ng may higher output na aftermarket. Your current alternator charging system is okey but cannot handle the demand that you have. Again, estimate your current demands this gives you a rough estimate of how much your current your sounds system is going to require. Do this before making drastic change baka hindi mo magustuhan ang outcome. Good luck
January 16th, 2008 10:23 AM #5
sir di kaya pasira na battery mo????
pero sir kung naka on naman ang aircon alam ko natural lang sa sasakyan yun eh
kasi lahat ng auto namin ganun po talaga eh
Tsikot Member Rank 4
- Jan 2003
- 2,979
January 16th, 2008 04:59 PM #6experience ko its either alternator or battery. baka palitin na battery mo or sira na alternator mo. yun alternator, replace mo yun buong unit. wag ka na kumuha ng surplus. 4 thou yun surplus pero di ka sure dyan. baka after a month bumigay yan katulad nung sa kin. nadamay tuloy yun in dash tv ko. yun bago is around 6 thou. kung ic lang eh around 1500 yan
January 17th, 2008 04:34 AM #7
whats the voltage rating when your engine is idle? how old is your battery? anyway re-check all the wirings again for loose connection. tighten battery clamps.
VinFast VF 3
