Results 1 to 10 of 13
August 9th, 2005 09:17 PM #1
Preferrably in QC area, with cost-effective service around P500 or less.
TIA :D
- Jan 1970
- 396
August 9th, 2005 10:15 PM #2you should go ahead and clean the intake manifold also. when mine was cleaned, the entire inside of the IM was covered in black soot. had mine cleaned at speedyfix. PM him for price.
Tsikot Member Rank 5
- Nov 2003
- 3,848
August 9th, 2005 10:46 PM #3yeah, the best results come when you clean the entire intake along with the throttle body.
the throttle body is like your 4 front teeth. the intake manifold is the rest of your mouth and teeth. cleaning just the front will still result in bad breath. hehehe!
August 9th, 2005 10:58 PM #4
...how long does it take to be cleaned? binabaklas ba yung buong throttle body?
- Nov 2003
- 3,848
August 10th, 2005 09:43 AM #5around 3-4 hours depending on the car.
yeah binabaklas throttle body, intake manifold, injectors, etc bago malinis.
August 10th, 2005 09:56 AM #6
Originally Posted by speedyfix
nag-spray na ko carb cleaner last weekend. not much change. pls pm price na rin po. tia!
- Nov 2003
- 3,848
August 10th, 2005 10:01 AM #7pm'd you na! yup, normally we recommend this every 40k kms. sooner if you have an open element air filter.
- Dec 2004
- 89
August 10th, 2005 10:17 AM #8ano po ba ang symptoms na kailangan na linisin ang throttle body? pa PM naman po ang price ng pagpapalinis ng TB and IM
- Apr 2005
- 99
August 10th, 2005 10:26 AM #9speedy fix,
do you clean throttle of diesel SUVs, say a 1995 nissan safari diesel?
- Apr 2005
- 99
August 10th, 2005 10:26 AM #10speedy fix,
do you clean throttle of diesel SUVs, say a 1995 nissan safari diesel? if yes, how much do you charge and how long will you clean it? thanks
have your compression checked... if Manual yang Montero mo... try mo patulak if ayaw mag start...
