Results 1 to 8 of 8
June 30th, 2004 04:57 PM #1
what can you say about a sentra eccs series 2(93mdl,1600cc,allpower,efi yata???) for a project car? applicable ba sa car na'to basic i/h/e mods and eventually performance plugs/hi-tension wires upgrades. accessible ba upgrades?. will it be worth it or should i go for an ae92 corolla, yung mga corolla kase na ka-price nito ay mga carb at single cam lang yata, then no power features pa. your ideas pls. tnx.
June 30th, 2004 05:02 PM #2
kung all-out project car, mag toyota ka na lang... mas maraming engine choices...
pero kung stage 1 mods lang (IHE) - pwede na rin nissan...
June 30th, 2004 05:17 PM #3
mas madali yata pormahan yung series 2 na sentra compared to the corolla. magandang paint job lang, lowering spring, mags and muffler ok na porma nun compared dun sa corolla
June 30th, 2004 08:59 PM #4Originally posted by iliad
My previous ride was a Sentra series 2 1.6 ECCS and the mods were:
-K&N cone filter
-4-2-1 headers (Nodalos)
-stainless steel freeflow muffler (Fremuff)
-2 inch exhaust piping (Nodalos)
-APEXi Super AFC (gen2)
-Stillen Fuel Pressure Riser
-MSD 6A ignition controller
-hi-tension wires
-Torquemaster sparkplugs
-Clutchmaster stage 1 clutch kit
-Eibach Sportline springs
-15 inch alloy mags (Rota)
-195/50/15 tires
with my setup (and I still have a couple 12 inch subwoofers in the back) I can usually beat most 1.6 cars in a drag except Civic Sir and heavily modifed VTi. BTW, its a big help if you lighten the car before the race, stuff like spare tire, tools, backseat, etc.
my measured times were: (street tires)
8.8sec 0-60mph (roughly 0-100kph)
15.8sec 1/4mile
My suggestion for your Project Sentra 2
-swap the GA16DE with a SR20DE or SR20DET
-if SR20DE, you can add a nitrous kit for another 50 HP.
-if SR20DET, well with 190 to 210hp (depending on engine version) do you actually need more??? :D
GA16DE = 110hp
GA16DE with turbo = 150hp
SR20DE = 140 to 145hp
SR20DET = 190 to 210hpLast edited by ghosthunter; June 30th, 2004 at 09:03 PM.
July 1st, 2004 11:17 AM #5
thanks for the suggestions, at least i now know na puede racing setup ang mga series2 sentras. gagamitin ko rin kase pang daily city driving ang car, what can you say about the fuel consumption of both 1.6 s2 sentra and ae92 corolla.
July 1st, 2004 12:58 PM #6
corolla is more fuel efficient. sentra definitely higher fuel consumption.
July 1st, 2004 01:59 PM #7
I do think the Sentra should be more fuel efficient since its running on an EFI engine already with a lighter body (if i'm not mistaken).
If you're keeping the stock engines, then the Sentra would be the choice for me hands down. If you plan to change engines, i think its easier to do the 4AGE swap on a 'rolla... The SR20DE/DET swap on a Sentra is more time consuming and costly (to get it done properly) but will be worth it at the end. Just dont forget to upgrade the suspension and brakes.
As Ghosthunter mentioned, the B13 GA16DE is quite responsive to bolt-on mods. One of the Nissanbayan members with an intake, and headers mod put down around 100whp on the dyno before... a lot goes down to proper tuning and condition of the engine.
my .002
July 1st, 2004 09:06 PM #8Originally posted by iliad
With a turbo on my GA16DE (GA16DET), my fuel milage dropped to 4.5km/L with the same driving habits.
The factory brakes are good enough for a 1.6 turbo setup but better tires are recommended.
FYI, my sentra understeered at the limit. Since I was concentrating on drag racing, it didn't really matter for me.
Thread was made nung 2018 pa po sir.
