Results 1 to 18 of 18
    Sep 2005
    Bros what kaya problem sa car ko 7g Galant SS A/T. Dati kasi kahit 180kph ok sinubukan ko sa NLEX last week dinidiin ko accelerator ayaw na umabante parang sakal at parang umuubo parang bigat ng arangkada. Sa timing kaya yun? needs tuneup? or sparkplugs? Mods ko is cone filter and muffler lang. Ano dapat ko patignan? TIA mga Ser!
    Quote Originally Posted by romtrt View Post
    When was your last tuneup? (how many kilimeters ago?)
    Have you changed your sparkplugs, fuel filter? Had the throttle body been cleaned? Have you checked the ignition timing?
    May 2005
    do a tune up first or worst sliding clutch na yan. kahit kasi automatic, meron pa ring clutch sa loob yan.
    try changing the tranny oil...baka masyado ng malabnaw...if this does not help baka time to overhaul you A/T tranny.
    kung timing or tune up kasi yan, ramdam mo sa takbo (hindi ito matino and the fuel consumption is bad), pati na rin sa possible hard start.
    pero kung okay naman ang takbo at parang hatak lang kulag...the tranny is one of the possible culprit.
    Bossing, when was your last tune up? If recently lang and ganyan pa rin takbo ng ride niyo, baka time na para mag pa-overhaul, pero i suggest pa check niyo po sa mga mechanic baka may remedyo sila na makakatipid sa inyo ng malaki at less hassle.
    Jun 2004
    check engine timing using timing light (if applicable)
Help! hanggang 140kph lang ayaw na..
