Results 1 to 7 of 7
- Apr 2007
- 66
May 27th, 2007 01:00 AM #1Guys, Ndi ko alam kung may problema ung gamit kong lancer kc pag apak ng 3k+ ung rpm parang awlang dagdag hatak lumalakas lang ung tunog ng engine. normal ba to? or may problema?
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 27th, 2007 09:02 AM #4
dalhin na sa speedyfix yan!!! ...I just went there yesterday by the way. problem solved.
- Apr 2007
- 66
- Nov 2003
- 3,848
May 27th, 2007 09:31 AM #6how can you estimate how much will be spent if hindi pa alam what the problem is with the car?
May 29th, 2007 02:47 PM #7
kung clutch ang problema, prepare to spend around 3k to 5k depending if you will use original or replacement parts.
you will have to replace kasi a number of parts para isang trabaho na lang like, clutch disc, pressure plate, release bearing and rear crank oil seal. that is kung sliding clutch na ride mo.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
