Results 1 to 16 of 16
    Aug 2010
    to fellow adventure diesel owners nangyari na po ba sa inyo ito. ito po ay parang grinding sound bakal sa bakal na tunog sa under chassis maririnig ang grinding sound pag slightly press ang accelerator pedal at pag nirelease ito dahan dahan kahit neutral maririnig pa din pina check up ko na sa underchassis specialist ang sasakyan pero hindi nila malaman kung san nang gagaling ang grinding sound. paki share naman po ang kung meron man kayo experince about sa problemang ito baka makatulong po. salamat mga kasama.
    i don't have an adventure, but my car has an exhaust system. perhaps your exhaust system is vibrating too much.. patingin mo sa tambutsero...
    at nung pinatsek mo, lumabas ba yung tunog? hindi ko ma-isip na naririnig yung tunog ngunit nasa ilalim ka na at hindi pa rin malaman kung san nanggagaling...
    Aug 2010
    sir dr. d salamat sa reply, na check na nila lahat halos, sa exhaust system ok naman lahat ng support, nakaka irita na kasi yung grinding sound. dati sir pina check ko may nakitang crack sa muffler akala ko ok na nung nahinang ayun ganun pa din pina check ko uli may nakitang broken bracket parang support ng exhaust naka attache sa engine nahinang nila, after non walang nagbago.
    May 2009
    Quote Originally Posted by samleggy View Post
    mahirap magtroubleshoot over the net lalu na kung sounds....pero wild guess ko eh pilot bearing or throw out bearing (provided manual transmission yan).
    Apr 2013
    Quote Originally Posted by miked View Post
    Yup maybe release bearing,as you have said(grinding sound)it means rotating yun object,just my 2cents
    Aug 2010
    Quote Originally Posted by cardict View Post
    sir may punto ka, kasi habang nirerekease mo yung accelerator pedal mas malakas yung grinding sound. sir may idea kaba kung magkanu tong bearing na to, most probably eto na talaga sira non.
    Apr 2013
    Have no idea right now how much it cost,but for sure,baba transmission mo,pa check mo na pati clutch lining at pressure plate
    Apr 2013
    Do another check,apakan mo clutch pedal assuming Manual transmission mo,pag nawala ingay that's it,pag ni release mo at umingay tapos na problema mo
    Aug 2010
    [QUOTE=cardict;2300706]Do another check,apakan mo clutch pedal assuming Manual transmission mo,pag nawala ingay that's it,pag ni release mo at umingay tapos na problema mo[/
    thanks sir i will try this at pa check ko na lahat para sure.
    sa Toyota 2C ko noong palitan ng release bearing 650 pesos yung Koyo which is the original brand, Ibaba ang transmission niyan para mapalitan at makikita din ang kondisyon ng clutch disc, at pressure plate. 1,500 ang bayad ko sa labor at palit din ng gear oil.
    Aug 2010
    sir miked pina check ko po yan sa shop ang cross joint daw sa propeller ayoko agad maniwala so dinala ko sa ibang shop nagcheck sila ok pa daw yung cross joint. nakakalito nga e
2007 adventure diesel, strange sound
