Results 1 to 9 of 9
    Oct 2004
    What are the other possible parts to be replaced aside from the timing belt.
    Sir. may mga previous thread na po tayo about timing belt. Gamit na lang po kayo ng search forum.
    Oct 2004
    I have done search forum but no same topic is being shown... tnx.
    Aug 2004
    tensioner bearings, water pump...
    sige, enumerate ko na rin..
    1. syempre yung timing belt;
    2. water pump, kasi halos katabi na rin ito ng timing belt. para isang bukasan na lang and tipid sa labor.
    3. tensioner bearing. same reason as item 2.
    whilte you are at it, consider replacing the following items too kung hindi pa nagagawa..
    1. alternator belt
    2. aircon belt
    3. engine support left side (kung hindi pa sira).
    add to that the crank and camshaft seals para isang tanggalan na lang
    Nov 2003
    tama. and just have the mechanic who does it give the rest of the engine a once over so you can check everything well
    Aug 2005
    hala andyan kna eh so palitan mo na dapat palitan.. pra bago lahat sa side..
Replacing Timing belt
