Results 1 to 5 of 5
- Jul 2009
- 57
September 9th, 2009 12:05 PM #1mga sir, yong 2door rav4 ng pinsan ko pag on pa lang e umaandar na yong radiator fan. dirediretso na yun hindi tumitigil basta naka on. anu kaya problema dun mga sir? nagpalit na daw siya ng thermostat at thermo switch pero ganun pa rin daw. panu kaya yun mga sir? simple lang ba na problema yun? kaya kayang i diy? ehehe.. help naman jan mga sir
tia
September 19th, 2009 07:14 PM #2
trx333,
if your cuz's rav4 is equipped with a 3sfe engine, the fan thermoswitch is normally closed and opens when the coolant temperature reaches 98 degrees celsius. the radiator fan relay is normally open with the ignition switch in the ON position and closes when the control circuit of the relay is deactivated by the opening of the fan thermoswitch. try grounding the terminal lead to the fan thermoswitch, it should turn the fan off
jick
- Jul 2009
- 57
September 22nd, 2009 02:46 PM #3sir jick, my cousin's car is doing good now. thanks! and sorry for the late reply. dinala niya kasi sa servitek dati yun, sabi dun baka sa thermostat daw at sa thermoswitch, kaya bumili pinsan ko ng bago. tas nilagay nila dun sa servitek yun. at ayun nga ganun pa din
walang pinagbago. the next weekend, dinala namin sa ibang shop. a shop with no name
. at ayun nga, nagawa nila, pinalitan lang ng fuse
- Jul 2009
- 57
September 22nd, 2009 02:53 PM #4sir jick, my cousin's car is doing good now. thanks! and sorry for the late reply. dinala niya kasi sa servitek dati yun, sabi dun baka sa thermostat daw at sa thermoswitch, kaya bumili pinsan ko ng bago. tas nilagay nila dun sa servitek yun. at ayun nga ganun pa din
- Jul 2009
- 57
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
