Results 1 to 10 of 11
- Aug 2003
- 46
May 18th, 2005 11:56 PM #1pag white smoke na lumalabas meaning nito is sira ang valve seal diba?
ano pala ang nag ca-cause para masira ang valve seal?
Tsikot Member Rank 3
- Dec 2003
- 546
May 19th, 2005 01:49 AM #3afrasay akala ko black smoke lalabas pag bad F/A mixture, running rich, pag running lean wala naman ata smoke.
Pag maputi ang usok, malamang valve seal, dati may sasakyan ako, bumaga ng white smoke, nun pinabayaan ko naging black smoke after ilang weeks.
yun pala sire na ang valve seal.
Natural lang masisira ang valve seal, goma lang kasi yan na may spring fastener sa ulo nya, para hindi makapasok oil
- Dec 2003
- 546
May 19th, 2005 01:50 AM #4yung white smoke pwede rin busted cylinder head gasket, at may pumapasok ng tubig sa chambers, kaya pag combustion, puti usok
- May 2005
- 208
May 19th, 2005 02:20 AM #5same problem as my car now. white smoke coming out of my tambutcho.... sabi nga ng mekanino valve seal. pero dko pa napagawa. magkano umabot yung sayo vin888?
sabi nung siraniko baka kaya nasira yung valve seal ko dahil nung pumutok yung radiator hose ko. few weeks ago.... pero ewan kung dun nga talaga nang galing.. case 2 case basis din cguro yun.
- Dec 2004
- 47
May 19th, 2005 04:21 AM #7naghahalo na ung tubig at langis mo sa makina kaya kailangan palit head gasket na yan.
patignan mo na rin ung mga piston at valvola nya baka me tama na rin sila.
- Aug 2003
- 46
May 19th, 2005 07:44 AM #8is it true pag ur driving tapos kulang ang power pinipilit naisisra ang valce seal?
May 19th, 2005 08:49 AM #9
If you get black smoke, it could be your engine is running too rich.
If you get white smoke and you notice that your ride is loosing oil, then the best would be to get a compression test done (wet and dry) first as thatr would help determine whether it is a piston ring, seals, etc...
Toyota is my choice
- Aug 2005
- 2,063
September 26th, 2005 12:35 AM #10this is the answer to my question. thanx guyz. 1 year na ata tong puting usok ko ngayun bumigay na ang compresion. pa test nga bukas.. magkano ba mag pa full compresion TEST?
How about 97 LXi?
Civic horsepower
