Results 1 to 12 of 12
    Jun 2006
    Ok ba to? Comments pls specially on their full syn oil and ATF fluid.
    for me ok siya gamit ko siya sa diesel ko....
    May 2004
    i use 15w40 elf performance dx for my 4jg2 engine.
    Nov 2003
    if you get the real stuff it's supposed to be really good pero i heard it's being repacked by conoco na locally so i'm not sure na of the quality.
    Jun 2006
    How do they compare to Motul? I read somewhere that their full synth is esther based, is this true?
    Also since they are part of the Total group, how are they marketed? Higher end oil compared to Total or what?
    Nov 2003
    oh, i'm not sure if they are ester based. you may want to google it nalang.
    as far as i know there is hardly any marketing done and they are doing most of the selling to companied who use diesel vehicles.
    Sep 2006
    their high end stuff are ester base just like Motul.
    i guess this ones are hard to find. i got elf full synthetic but its for my motorcycle. namamahalan kasi ako na sa repsol.
    Aug 2004
    Elf = Total in terms of lubricants daw. Same banana different wrapper.
    I'm using Total's semi-syn 15W50 (ata) and ok naman. Sabi pa ng mekaniko: "Ang bango!!!"
    Jun 2006
    Using Total ATF dex III since May. So far no complaints. Although, I did notice that while it is colored red like most ATF, it looks clear on the dipstick.
    Aug 2005
    Quote Originally Posted by userfriendly View Post
    na try ko ung motor oil but not the synthetic, masyadong malabnaw ngtunugan valves ko kaya change oil uli ako, fake ata
    Nov 2003
    i don't think the synthetic is ester based. only motul and redline oils use ester as far as i know.
elf lubricants
