since i started maintaining our cars. i have always been puzzled by single grade and multigrade oils. when should u use a single grade oil (sae 40) or multigrade oil? my patrol uses 9ltrs of oil so cost is a factor (single grades are cheaper) but i'm concidering other fartors like performance and wear & tear of the engine.
The single grade oil retains the same thickness/viscosity whatever the driving temperature is. The double grade one (e.g. 20W-50) obviously has variable thickness. The first number (20) is how thick the oil is when the engine is cold. W stands for winter. The last number (50) is the oil viscosity of a hot motor.
