Results 1 to 5 of 5
- May 2004
- 36
June 30th, 2004 10:37 PM #1Guys, need help lang. Planning to get lowering springs for my 99 LXi. I'm eyeing Neuspeed greens.
1) I'm just wondering kung may specific Neuspeed part number for that model, or is it generic? What I'm avoiding is ending up with a higher front than rear fender-to-wheel clearance.
2) do i need to replace my struts? or the stock will do just fine with the lowered springs?
slamat!
June 30th, 2004 11:37 PM #2
i think neuspeed springs are distinguished by color. green ang kadalasan kong nakikita for civics. subsob ng konti yung bagsak. 1.75" sa harap, 1.5" sa likod. it would be best to replace your struts to aftermarket ones, pero the stock ones will do just fine. isabay mo nalang yung pagbili ng bago kapag bumigay na yung OEM ones mo.
guys, correct me if i'm wrong nalang.
- 124
July 1st, 2004 10:37 AM #3yep green nga talaga yung neuspeed greens. Ganito gamit ko. Pero baka hindi 1.75" ang bagsak sa harap nyan, since magaang yung engine mo as compared sa VTi or SiR. Baka mga 1.5" drop ka lang sa harap. May neuspeed yellows rin (2" drop) and blacks (.75"-1" drop - hard to find)
- 259
July 1st, 2004 08:47 PM #4you don't really need to replace the struts. but it would be better if you do. and so much the better if you replace the other suspension components to match your set up.
- May 2004
- 36
July 1st, 2004 09:40 PM #5di ba pangit kung 1.5 drop lang instead of 1.75? ganun ba kasama tingnan o not that obvious? I was thinking of putting a ballast to add to the weight up front ... it's just a funny thought pero baka may gumagawa. hehe.
what are the obvious symptoms that the struts are about to give? just wanted to optimize the use of the stocks before replacing it. besides, it'd give me more time to save up.
slamat sa sagot sa earlier questions, guys.
naalala kong bigla... you can also have your valve clearance checked... baka di na sya nagsasara ng...
