Results 1 to 10 of 10
    Mar 2003
    gud day sa lahat .... lalu na po sa mga old skulers :jump2:
    help!!! :question:
    question ko po:
    have you ever experienced driving/seen a car na tipong pag-nag rev up eh lumalakas din ang ac, headlight, brake light etc.? at pagrelease eh humihina naman...
    yung '82 SE CORONA kasi namin ganito ang nangyayari (not to mention pag on ng AC hirap na ang makina)...
    eh kaka-overhaul lang ng engine nito 2 weeks ago, palit lahat ng laman loob engline block lang yata natira na luma eh hehehehe
    tulong naman po mga TSIKOT GURUZZZZ
    sagot nyo po? :
    .......... btw, ITS GOOD TO BE BACK!!! :bald:
    sssssalllammmaaasss!!!
    it's an alternator thing, but im not an expert in these matters.
    Yup sa Electrical mo yan...Medyo old car na....some people place relays for their lamps etc....mukhang mahina na alternator mo...may 83 Corolla GL ako dati ganyan....gastado na pala yung carbon brush sa alternator
    Battery or your voltage regulator (external or internal sa alternator). Bale ang alternator na lang ang gumagana kaya pag nag rev up lakas din ilaw, radio, etc.
    calling lolo ungas...ingkong afrasay..etc!!!old schoolers daw!!!
    charing lang po mga ninong..
    i'll go for afrasay hunch....voltage regulator problem malamang....hindi rin katataka kung may "leak" ang wirings mo kasi luma na ang wirings and malamang insufficient ground contacts. Next possible suspect ko would be the alternator itself is dying na....try to get higher ampere rating should you choose to replace it. 100Amps or better would be good.
    Ingat ka at baka overcharging iyan. Nangyari sa Besta ko dati. Sunog ang socket ng headlamps. Yikes!
    Mar 2003
    volltage regulator and alternator?
    ok guys, pa-check ko right away....
    maraming salamat po!
    btw, any rough estimate sa mga ito kung mgakano nagre-range ang price?
    tnx ulit!!!
    alternator 110 amp 5,000 php pang starex, regulator IC built-in 1,500 php.
    Mar 2003
    ok! i'll check...... tnx a lot AFRASAY!!!
    :beard:
Q2ololdskulers
