Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Aug 2004
    Quote Originally Posted by StAnger
    What do you think? Need your help! Hindi ako makatulog dahil dito! Hu..hu..
    a tune-up is definitely needed...
    a warm glass of milk before bedtime would help...
    Feb 2006
    Ok mga sirs, thank you, dalin ko na sa mekaniko pero since 1st time ko lang wala pa ko kilala na magaling na mekaniko sa tabi-tabi kaya sa car savers muna ako kahit mahal, highly recommended kasi ng utol ko. Tsaka para makatulog na ng mahimbing. :sleep:
    Aug 2005
    pa check mo lahat (general check up)
    Feb 2006
    Hi guys! Just to update you, napa preventive maintenance ko na yung car including change oil, tune up. Chineck lahat pati carburador, starter, battery, pinalitan spark plugs, contact points, but ganun pa rin yung car ko, hirap mag start sa umaga. So i asked yung mekaniko kung normal ba yun, sabi nya normal daw yun sa model ko (corolla XE 1999), kelangan ko apakan gas pag mag start ako. My car is not yet electronic fuel.
    So what do you think guys? Lipat ako ng mekaniko? Thanks in advance!
    Dec 2002
    My corolla 96 xe did at one time had difficulty in starting in the morning. Here are the things I did overhaul the carburettor, there was also oil in my spark plug so I had the spark plug oil seals replaced, and voila the car starts like new one click ok na. BTW the mileage of the car now is only 58k km. whats the mileage of your corolla?
    Feb 2006
    Quote Originally Posted by johnart
    Sir 72K na po mileage ko. Nag general check up ok naman daw lahat... So its not normal na lagyan ko pa ng gas pag start? Ty.
    Apr 2005
    johnart, san ka nagpagawa?
    i don't think that's normal. baka mag flood pa engine mo...dagdag hassle yan
    ask mo na lang johnart kung saan siya pagawa tapos doon ka na din
Problem when starting
