Results 1 to 9 of 9
- Aug 2003
- 9,720
January 3rd, 2005 09:47 AM #1my ride never really felt like it accelerated very well, and i've blamed this on improper shifting on my part. pero recenly kasi napansin ko na at certain times, it seems a lot more responsive than usual -- dati rati kasi you can feel a slight delay between pushing down on the gas and the car actually going faster. at certain moments kasi ang ganda ng response. wala naman akong pinalitan. problema kaya to sa timing?
January 3rd, 2005 10:04 AM #2
it could also be the fuel you are using.
btw when was the last time you had a tune-up?
- Aug 2003
- 9,720
January 3rd, 2005 06:13 PM #3benchph1::btw when was the last time you had a tune-up?
um....never? ;) seriously though, the last tuneup was in the 90's pa...
Tsikot Member Rank 5
- Nov 2003
- 3,848
January 4th, 2005 11:52 AM #5never? hehe! ok ah!!!
actually, replacing the plugs, air filter, fuel filter and oil is most of the maintenance a car usually needs.
replace all of that and you shouold feel new vigor in the way the car drives.
- Jan 2005
- 5
January 5th, 2005 02:29 AM #6After you have replaced all of the things mentioned above, have your timing checked. The acceleration lag that you mentioned may have something to do with timing that is a bit retarded.
- Aug 2003
- 9,720
January 7th, 2005 10:13 AM #9a very old '89 corolla ;) bale napa oil/fuel filter/spark plug/air filter change ko na sya lately, but sadly DIY lang(i have a front yard with huge oil stains to prove that), ung timing never ko pa nacheck
Not fully sealed. The coolant pressure cap keeps the pressure inside the system at a set...
