Results 1 to 8 of 8
    Aug 2003
    i'm still getting a few drips of oil from my ride, even after changing the oil seals around the engine. what's strange is that the portion directly above the area (where the engine meets the pan/where the gasket is) is drenched in oil. di ba dapat pag ung gaskt ang problema, that portion shouldn't be oily? or posible na matalamsikan ng langis while running?
    Aug 2005
    nag pa engine wash kna po sir?
    What engine is that? Kakapalit lang namin sa crakshaft gasket ng Sentra GA14. Initially mukhang oil pan leak siya kasi dun naiipon yung langis.
    Mahirap din macheck kung sa crankshaft galing kasi ang laki ng crankshaft pulley and hindi ko makapa yung likod kung basa ng oil.
    Aug 2003
    it's an old, humble 2E engine on an '89 corolla B). di ko pa naipaengine wash, pero may drips of oil kasi sa driveway
    Jul 2005
    mahirap hanapin yan. kung ako sayo pa engine wash mo tapos itrace mo na lang ung san nanggagaling yung tagas. baka galing sa gitna yan. sa may timing chain/belt cover, etc.
    Nov 2003
    if the oil is above the part you replaced then the oil leak is comming from somewhere else. gravity lang yan... oil can't go up
    Apr 2005
    you need to identify exactly where the leak is. my guess is oil pan resealing.
    pa engine wash mo po para ma-trace kung san talaga yun may oil leak. para sure talaga po.
oil pan leak?
