Results 1 to 4 of 4
May 13th, 2006 11:07 PM #1
my hilander slx 99 model got hit at the right side just above the rear wheel. got the alignments checked and found out that my rear axle is misaligned.
has the ff data:
set back -0.51 deg
thrust angle +0.40
LH RH
max dif camber +0.32 -0.28
half-toe max dif +0.45 -0.35
how can i correct these? saan pong shop may gumagawa nito alignment ng rear wheel axle?
will very much appreciate kung may ma refer kayo na pagpapagawaan
09189166527 is my number.
thank you very much in advance
carlo
May 13th, 2006 11:10 PM #2
i'd go to the casa. afaik some casa repair bays are open even on sundays.
May 13th, 2006 11:16 PM #3
The dealer's body shop can usually do it. Or try crash repair facilities like Alex Car Restoration in Q.C.
May 14th, 2006 09:47 AM #4
Try Velocity Motors dyan sa Nueve de Pebrero, they do computerized alignment, although not sure kung body at chassis lang kaya nila.
VinFast VF 3
