Results 1 to 7 of 7
- Aug 2007
- 4
August 6th, 2007 06:41 PM #1Guys, Good Evening!
I'm just new here since ngayon lang ako nagkakotse,hehehe. I had my 2nd hand Daewoo Racer Gti 1994 model. My problem is while running and when I stepped in the clutch pedal to change gear ay namamatay yung makina. Hindi naman siya palagi pero uncomfortable talaga especially during traffic when you always step in the clutch pedal. Pls help me coz hindi ko alam anong part ang galawin ko.
Thanks in advance....
August 7th, 2007 10:40 AM #2
daming kailangang i-check dyan sa situation mo:
a. check the idling first, it may be too low.
b. tune-up. baka kailangan mong magpalit na ng plugs and i-timing yung makina.
check mo muna yang dalawang yan. pag nagluluko pa din, post ka ulit dito.
- Aug 2007
- 4
August 8th, 2007 11:10 AM #3thanks for advice. btw, idling ko is at 800 rpm with or w/out AC. Kailangan pa ba tune up yung injection car models? Paano mag increase ng idling?
- Aug 2007
- 4
August 13th, 2007 10:11 AM #4paano po mag increase ng idling nga daewoo racer Gti. Injection model po ito. pls help fellow tsikoteers.
Tsikot Member Rank 3
- Oct 2006
- 760
August 14th, 2007 09:20 AM #6
Sa tingin ko ok lang idling mo hindi ba siya nanginginig or bumababa . Baka naman may vacuum leak yung auto mo or madumi lang yung throttle body. Mas maganda dalin mo na sa mekaniko mo para sa engine tune-up. Symptoms na kasi yan na kailangan ng tune-up ang tsikot mo.
For modern cars... people forget that coolants have a lifespan and that they need to be replaced. ...
