Results 1 to 3 of 3
July 27th, 2007 09:35 AM #1
hello everyone! my 2000 pajero field master is starting to show some wear and tear after 60+ k kms. where can i have items such as fanbelts and a small oil leak from the upper engine compartment repaired? i live in the alabang area. any input is much appreciated. thank you. nice day to all!
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 30th, 2007 01:22 PM #3
as speedyfix said easy lang any gas station or shop jan with good reputation pwede na. buy first sa casa ng cam end cover seal front and back (2) yan ung halfmoon na rubber (P2++ each). baka wala ka rin makita sa auto supply jan medyo hirap hanapin puro pang old pajero ang available.jan prone magleak ung oil. replace valve cover gasket maski replacement lang pwede na P180 ung orig nasa P8++ at valve cover washer seal (P150 each ata) ung orig na rin dahil ung replacement maliit ang circumperence niya. DIY k 2 months ago ok hangang ngayon alana leak
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
