yung gause ko sa gitna, nababwasan yung oil, may auir bubbles na, how do i fix it anf fill it up ulit?
Here it is: http://www.4x4wire.com/mitsubishi/te.../inclinometer/
Mineral oil available from drug store/pharmacy.
Afrasay did it on his GEN I.
Originally Posted by OTEP
Hmmm... my inclinometer also needs fix as well...
otep,
know anyone who can do it for a fee????di me kasi DIY guy, DIY lang me sa alam mo na.......![]()
hehehe![]()
may libre pa ba ngayon? pameryadahin mo na lang. o kaya pamasahe papunta sa inyo.
hehe.. oo nga no... for FREE din unang basa ko...Originally Posted by KCboy
how about the illumination nung center gauges? pundido na yung light nung compass/outside temp nung paj gen 2.5 namin e. kung madali lang gawin at readily available yung bulb na ipapalit ako na ang gagawa
The compass bulb is available from your Mitsubishi dealer. Cost me Php75.00. Probably cheaper in El Dorado. It's called a CONSOLE BULB. The bulb and the socket are sold as a unit. But the parts counter guy seems not to know about it. At least they had the parts book [and my busted bulb] to help the search.
Pretty easy to install. The center cluster can be taken out by just unscrewing the two screws on either side.
after that...the center console is secured to the dash as well by 4 screws...and once that's off, disconnect the ribbon cable going to the compass. :DOriginally Posted by OTEP
and then kanya-kanyang baklas na to the three pods sa center cluster.
You can pretty much play that part by ear. hehehe.
Dear Sirs,
I tried refilling it, but unfortunately, nasira ko. Does anyone know where I can get a replacement? Nasira ko yung plastic, balak ko palitan na lang. thanks.
estee96,
kaya id rather have someone installed for me that DIY....makakasira lang me.
guys,
do you have an idea where to purchase surplus digital temperature center gauges?
Thanks for your inputs.
estee96 and stortaliz888,
Maraming surplus sa banawe cost about 3K to 3.5K pesos, isang set na yun Altimeter, inclinometer and compas.
KCboy,
Bili ka na lang ng surplus tapos bilhin ko sayo yung digital compass. tipid diba.
Nyll,
Maraming salamat...
Nangyari din sa akin yan at ginawa ko bumili ako sa mercury ng mineral oil kaso lang ng refill ko nabasag un plastic. Ginawa ko naghanap ako takip ng nido sinukat ko at mightybond at sealant, kunting dry lang ayos na. Ang kailangan mag refill is to inject kailangan lang ng tiyaga at natatapon....Baka makatulong sa inyo...
where do you inject the needle mga sirs?im planning to DIY lang since nasa prov. un pajero ko,thanksOriginally Posted by stortaliz888
stortaliz888,
I notice that your location is Cavite. Saan ka sa Cavite? Im from Cavite too.
