Results 1 to 11 of 11
    May 2004
    Ano kaya possible cause... Small amount of oil sa may 1 sparkplug... other 3 wala naman...
    Check for worn valve guides, valve stem seals and/or piston rings. Replacing the spark plug may help for a short time, but the new plug will soon foul.
    Feb 2005
    could it be that the plug was not tight enough?
    Aug 2005
    if normal lng ang hatak at minsan slight hard start maybe busted valve seals . change valve seals or for the meantime clean up plugs regularly.
    May 2004
    How much kaya magagastos ko kung change ng valve seal? PH12 engine.. Kahit + - lang...
    Aug 2005
    each seals has its price. but you can buy package like 12 seals for 12 valve engine. Go for replacement or casa. I think less 2T for 12 seals.
    Nov 2003
    if the oil is on top then it's the spark plug oil seal. kung nasa tip na ng plug yung oil then you have to open up the engine.
    Aug 2005
    Quote Originally Posted by speedyfix
    sir pwde po elaborate? di ko kasi na get kung saan yung top and tip of the spark plugs.
    sorry sir huh..
    Nov 2003
    tip is yung dulo, yung electrode.
    top is where the socket attatches when you remove the plug
    Aug 2006
    Hi just wanted to revive this question.
    I have the same problem for PH16 engine i just changed the valve seals last year since pumpasok sa intake mainifold yung oil.
    Now i notticed that one spark plug #4 is oil fouled. Very minimal.
    I am planning to change the valve seals for that culprit.
    Any advice of valve guides na ito milage is arou 115k Honda Civic VTi Ph16 engine.
    Thanks!
    May 2012
    naexperience ko to sa GSR ko, pinalitan lang ng mekaniko yung spark plug seal, more or less 200 pesos each.
    AFAIK basta di nausok ng white ang muffler mo ok ang valve seal mo, kapag minimal damage sa valve seal sa umaga o unang start lang may usok coz nag accumulate lang ang langis habang nakapark ng matagal, while running wala na white smoke unless talagang damaged na valve seal
Oil sa Spark plug
