Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Apr 2006
    guys tanong ko lang. ano difference (aside from the obvious) nung fresh air and recirculate mode ng aircon? alin mas matipid? alin mas recommended.
    pasensiya na, newbie lang po. many thanks.
    Feb 2005
    by definition, pag aircondition, dapat talaga, may fresh-air na-iintroduce sa isang area at a given particular time.
    Pero setting it in fresh-air mode in the city, baka di fresh air makuha mo, kundi usok mula sa mga jeepneys and buses.
    REcirculate, you'l let the air circulate around the cabin.
    May 2005
    economy wise, mas matipid yung re-circulating kasi, malamig na yung paikot-ikot lang unlike pag bukas vent mo for fresh air, higher temp na palalamigin pa ng cooling system, thus more energy required.
    I only use the "fresh air mode" kapag nasa highway or walang kasalubong/kasabay na ibang sasakyan (lalo na mga jeep/trikes kasi amoy na amoy ang exhaust nila).
  5. #5
    and in our country, kung nag-ffresh-air ka, mapapaaga ang linis mo ng airconditioning system mo...so ganito yan, just set it to recirculate..and if you want fresh air, just open the window...since di mo naman pinatay ung aircon, so no change in consumption, pero mas matagal nga lang lumamig dahil di nakakamaintain ng lamig sa cabin,e...
    Aug 2004
    hindi bagay sa atin dito ang fresh-air mode. wala na kasing fresh-air dito halos sa manila. pollution lang papasok sa vent mo pag ginamit mo ang mode na to.
    in other places/countries na malamig at less yung pollution maganda gamitin itong fresh-air mode. pag outside temperature is 15'C or lower kahit fan nalang gamitin mo ok na yung fresh-air mode.
    Dec 2003
    recirculate ang akin kase kung fresh air fresh na fresh ang usok na maamoy ko...
    Ginagawa ko na lang naka on ang aircon habang naka windows down lalo na kapag sobrang init sa loob ng sasakyan..
    May 2005
    sa Baguio ,applicable kaya ang fresh air mode?
    Oct 2003
    circulate na lang. not recommended for Phil. environment.
    After ko pagawa yun aircon ko kay mang mario napansin ko naamoy ko yun usok sa labas, i found out na naka fresh air mode ako. Observation ko lang is mas malamig yun aircon pag naka fresh air kaysa naka circulate but then again patay ka sa usok.
fresh air or recirculate
