Results 1 to 10 of 11
- May 2007
- 60
May 28th, 2007 12:56 PM #1mga bossing,
meron na bang gumamit sa inyo ng mga oil additives, yung mga hinahalo sa engine oil, that claims to stop tailpipe smoke emission?
effective ba itong mga ganito o masama ang magiging effect sa engine in the long run?
May 28th, 2007 01:28 PM #2
if you are adding something in your engine oil to prevent tailpipe emissions, then it might be your engine is leaking motor oil into your cylinders.
It might be better to give us a summary of what car your drive and what problems you have been having with it.
Anyway, it is better to cure the cause of the problem than just covering it up with some "miracle-cure" which may only work for a short time and do more damage in the long run.
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 30th, 2007 04:46 PM #4
The best cure for bad oil is to buy new oil.
Bad oil + Additive is nowhere near as good as Good Oil.
Toyota is my choice
- Aug 2005
- 2,063
Zombie
- Aug 2006
- 728
May 30th, 2007 08:21 PM #6a friend of mine uses these additives that "gives additional power, promotes cleaner burn and minimizes emmissions".
after a few months, we opened up his 4g63 for mods. the result: chunks of oil,grime and varnish literally stuck in his engine. we had to use screwdrivers to scrape the stuff out.
May 30th, 2007 08:23 PM #7
Gumamit na ako minsan nyan sa corolla, saglit lang andon nanaman ang usok.
its better to have your car checked, baka blowby nayan.Ouch!
Toyota is my choice
- Aug 2005
- 2,063
May 30th, 2007 09:24 PM #8Maybe it could help a little bit lesser smoke but wont cure the cause of it. IMO waste of money.
How about 97 LXi?
Civic horsepower
