Results 1 to 8 of 8
October 8th, 2006 09:47 PM #1
pansin ko lang nito lately...
ang tanong ko mga guru's ano po kayang parts sa suspension ang culprit?
tia
October 9th, 2006 11:38 AM #2
see if your tires are rubbing against your inner fender. check you CV joints.
October 9th, 2006 04:34 PM #4
afrasay: di ko masyado pansin sa tires kung nag-rubbed.
dj: size ng tires? 195 55 r15 po sir.
btw, I supposed yung right cv joint yung i-check right?Last edited by puroy; October 9th, 2006 at 04:50 PM. Reason: added reply
October 9th, 2006 04:36 PM #5
cv joints lang din naisip ko eh.
actually ito yung naging sakit nung oto ni ownertype...
October 9th, 2006 10:52 PM #6
malamang nga CV joint..Grugg gruuggg tugtugutug
ASAP pa check mo na iyan delikado pag mga underchassis trouble
kung nag rub naman tires mo kita naman sa wheel well or inner fender
kung mag gasgas
October 10th, 2006 06:54 PM #7
update ko lang. parang nawala bigla yung grinding kahapon lang. will continue to monitor kung babalik ulit. pag bumalik then better pa-check ko kay cruven (sa kanila kasi ako huling nagpagawa ng pang-ilalim).
additional problem: mga sir, pansin ko lang pang medyo hi-speed takbo ko then pag nadaan ako sa maalon na daan, yung sa driver side ko may sumasayad. check ko tires and fenders wala namang mga marks. ano kaya supension parts culprit dito? shocks kaya? tia
October 11th, 2006 02:23 AM #8
cv joint (right side) most probably for the grinding sound when turning right...
sumasayad? ours was solved when we replaced the ball mounts.
check your shocks kung may leak, if fluid type.
pag gas shocks... di ko alam. dalin na sa suking mechanic!
