Results 1 to 10 of 16
- Jan 2003
- 611
July 12th, 2003 10:32 PM #1I had my fiamms installed the other day...
The next morning, I had a hard time starting the car, I need to start it up twice before the engine starts... My battery is new naman...
If the problem is something to do with the "relay" for the fiamms, can I ask advice from you guys how to DIY...
Thanks!
July 12th, 2003 10:53 PM #2
Hmmm...mas malakas pa sa kuryenta ang headlamps at a/c mo. I doubt it kung yung FIAMMS ang at fault dito.
Baka malamig lang nung umaga or something.
- Jul 2003
- 579
July 13th, 2003 06:12 AM #3Umm..... try mo bunutin yung relay. if you still have a problem, baka may nagalaw lang sila sa paginstall.
- Jan 2003
- 611
July 13th, 2003 10:55 PM #4OTEP, parang hindi naman ganun kalamig that morning... the usual temp lang...
Bubbles, Ok, will do. But what if nawala na yung problem after ko alisin yung relay? Wag na mag relay?
Thanks.
July 14th, 2003 05:59 PM #5
:whoa: STOP don't remove the relay. ibalik mo na lang sa naginstall most probably mali ang wiring (kung yun ang cause ng hardstarting).
- Apr 2003
- 526
July 15th, 2003 12:53 PM #7dati yung sa amin nung tinanggal yung relay naging 'supot' yung bosch horns.
kailangan talaga yang relay na yan
- Jan 2003
- 611
July 16th, 2003 08:32 AM #8Rediesel, ibinalik ko sa nag-install yesterday, pero this morning, hardstarting pa din...
GlennSter, hindi po sa inyo. medyo malayo din pala yung shop nyo. i'm from paranaque pa kasi... (sana sa inyo na lang ako nagpa-install para no further problem like this...)
Kulang sa power yung battery ko? (tama ba?)
July 16th, 2003 09:15 AM #9
Kung na-check na ang wirings nyan at ayos naman. Hindi kaya ang alternator ang may sala? Battery only works before starting your engine, pag umaandar na ang engine your alternator supplies the current the whole vehilce needs. Baka di na kumakarga yung alternator kaya nadidiskarga ang battery? Better bring it to your suking battery dealer and have the alternator and battery checked naman.
Or your vehicle's fuel line has a problem... now this is from another angle to look on if the problem still exist.
Haka-haka lang po.
- Jan 2003
- 611
July 17th, 2003 10:10 PM #10Recent changes din sa car is the gas i use... from the start pa lang i use shell velocity then before i have the fiamms, i switched to vortex gold... 2 days ago i switched back to shell velocity tapos my problem with hardstarting no longer occured...
may connection ba yun???
Any reviews for the Triton GLX 4WD 6MT? Siya ata pinakasulit na middle 4WD variant. Price range...
2022 Mitsubishi Strada/Triton (6th Generation)
