Results 1 to 15 of 15
    Jul 2005
    Greetings fellow tsikoteers. Parang merong thread for this but i can't find it so gumawa nalang ako ng separate.
    Meron akong inquiry about acceleration. paminsan-minsan lang naman mangyari but im bothered bec pag-shift ko ng 2nd/third gear, mataas na rpm(2.5) pero mabagal or matagal ang arangkada. minsan sa stop light at ako ang nasa harapan, when the light turns green aabante nako and pag-shift 2nd gear naririnig ko na malakas tunog ng engine, high rpm na and ang tagal ng response. Some say it maybe the clutch lining. I dont know. Pls help. saan din ang shop na mahusay gumawa nito. sa mandaluyong or makati area sana. My car is ae92 1.6. TIA!
    sounds like slipping clutch...
    Aug 2006
    No doubt. I second the motion. Amen.
    Be ready with a new clutch assy. or clutch lining.
    May 2005
    parang sliding na clutch mo nga
    prepare na ng clutch disc,Release bearing and pressure plate
    para isang gawaan na lang
    Nov 2003
    have your mechanic test drive it. he should be able to tell you what's happening.
    Jul 2005
    Thanks for the replies... yep, i suppose its a sliding clutch, pero minsan lang mangyari but im still bothered. I better have it checked. siguro complete clutch assembly na palitan ko para lahat bago. what do you think? or maybe clutch lining lang. magkano kaya aabutin? Wala din akong alam na magaling gumawa nito, can you suggest some shops? Thanks again.
    Sep 2005
    Quote Originally Posted by duncan_sheek View Post
    sir,
    that is a sure indication of a sliding clutch. clutch disc, pressure plate, release bearing, and crankshaft oil seal should be replaced. Flywheel should be refaced. have it fixed asap with your favorite shop. mahirap tumirik sa kalsada.
    Jul 2005
    Quote Originally Posted by banaweonline View Post
    sir,
    musta sir? sayo ako umorder ng bendix break pads last year. kaw pa nag-deliver sa office ko sa makati. dont know if you still remember. was trying to text you again to ask for some car parts. anyway, pm mo nalang ako. tanong ko na din kung magkano complete set nun and what brand ang ok. Thanks.
    on a slightly different note, what if kung maingay ang release bearing mo ? does it have any effect sa clutch mo ? what would happen kung di mapalitan kaagad ang bearing na ito ?
    Nov 2003
    it will just get noisier over time and pedal feel has a tendency to get harder
    Jul 2005
    I had it fixed last saturday. Below are the parts that I replaced, including the cost:
    clutch disc 1,250
    pressure plate 1,800
    release bearing 460
    crankshaft oil seal 400
    labor 1,600
    total 5,510
    Hay salamat, natapos din problem ko with sliding clutch. Thanks for all the tips.
high rpm, delayed/slow acceleration
