Results 1 to 13 of 13
    Preferrably in QC area, with cost-effective service around P500 or less.
    TIA :D
    Jan 1970
    you should go ahead and clean the intake manifold also. when mine was cleaned, the entire inside of the IM was covered in black soot. had mine cleaned at speedyfix. PM him for price.
    Nov 2003
    yeah, the best results come when you clean the entire intake along with the throttle body.
    the throttle body is like your 4 front teeth. the intake manifold is the rest of your mouth and teeth. cleaning just the front will still result in bad breath. hehehe!
    Jan 2003
    ...how long does it take to be cleaned? binabaklas ba yung buong throttle body?
    Nov 2003
    around 3-4 hours depending on the car.
    yeah binabaklas throttle body, intake manifold, injectors, etc bago malinis.
    Apr 2005
    Quote Originally Posted by speedyfix
    sir, would you recommend this to a '98 toyota corolla xe (163T kms)? parang hirap kasi huminga kotse ko. baka bad breath. nag-spray na ko carb cleaner last weekend. not much change. pls pm price na rin po. tia!
    Nov 2003
    pm'd you na! yup, normally we recommend this every 40k kms. sooner if you have an open element air filter.
    Dec 2004
    ano po ba ang symptoms na kailangan na linisin ang throttle body? pa PM naman po ang price ng pagpapalinis ng TB and IM
    Apr 2005
    speedy fix,
    do you clean throttle of diesel SUVs, say a 1995 nissan safari diesel?
    Apr 2005
    speedy fix,
    do you clean throttle of diesel SUVs, say a 1995 nissan safari diesel? if yes, how much do you charge and how long will you clean it? thanks
    Nov 2003
    throttle lang?normally we charge 350 just for the throttle cleaning. shouldn't take too long...
    Speedy, magkano kung buong manifold na?
    Nov 2003
    text me or call me in the shop for the pricing nalang dude.
Shop that cleans throttle body?
