Results 1 to 6 of 6
- Dec 2007
- 1
December 10th, 2007 11:57 PM #1Hello po sirs,
Gusto ko lang po sana itanong if may nakakaalam or nakaexperience sa inyo ng ganitong problem. Napansin ko lang nung friday and today e. Kotse ko po is Honda City 2002.
1. Namamatay for a few seconds yung radio then it turns on again.
2. The head lights and the gauge lights dim (hinde naman namamatay pero noticeable na parang nagdidim sandali tapos babalik na sa dati).
3. Idle rpm increases from 600 to 1000 rpm momentarily then goes back to 600.
4. parang may faint clicking sound everytime this happens.
Lahat po ito nangyayari sabay sabay while in heavy trapik pag nakastop or usually before starting to move. pag high speeds naman sa expressway no problems so far. pag stuck in traffic at nakaidle or low speeds lang nangyayari sya every few minutes. parang regular interval nga e. pakiramdam ko nagrereset kotse ko parang computer every few minutes. hehehe...
hope may makatulong. i assume its something electrical but hinde po kasi ako familiar sa kotse e. natatakot lang ako tirikan sa edsa e lalo na pag nakikita ko halos mamatay yung mga lights ko e. but the engine never goes below the usual idle speed naman.
btw, i just had the battery replaced (wala pang 2 months) and tune up and changed oil mga two months ago din.
Maraming salamat po sa inyo!
December 11th, 2007 01:02 AM #2
Hello po Sir! Nagyari na po rin sa kotse ko yan and we found out na yung mga connectors sa battery ang maluwag. Hindi nasikipan ng lagay sa casa kaya ayun pinaayos ko agad at naging maayos na rin ang kotse ko.
Patignan na lang po ninyo ulit para sure lang... Hope its not that bad naman.. Ingat po lagi!
December 11th, 2007 03:10 AM #3
LadyRider could be right.
Check your connection, battery terminal, cable corrosions and alternator belt tension if everything is okey. Have also your alternator check if charging properly.
December 11th, 2007 10:11 AM #4
tama check mo battery mo o kaya alternator??? naka aircon ka ba pag nangyayari yun???
""baka naman me sleep mode kotse mo o kaya baka di mo pinagpapahinga hayy... joke""
December 11th, 2007 10:47 AM #5
dagdag ko lang mga bro, baka ang wiring sa alternator mo (or ang alternator mismo) pwede rin dun. Hanap ka na lang ng reliable na electrician . . .
December 11th, 2007 11:12 AM #6
pwedeng alternator yan kasi ganyan din yung nangyari sa car ko before, nagpalit lang ako ng alternator, so far wala na ko nararamdaman na ganyan..
