Sir paano po ba ginagawa dito mga 2 mm lang naman yung natanggal sa dulo ng pintuan kaso baka simulan ng kalawang kita kasi yung bakal, balak ko sana pahiran ng rust converter ( pls suggest any good brand) using cotton buds then paint (what type ba sa bakal ng kotse)
o may mas maganda na procedure
another one is while cleaning my car today I noticed a corroded spot on the roof mga less than 1 mm in diameter ( 92 model na kasi ) pwede din ba DIY to o ano po magandang gawin
if it is too small and not worth having repainted yet, i just buy a cheap acrilyc paint(nail polish),lots of colors to choose from. and it last for couple of years.
Ilan taon na ba kotse mo? Matagal tagal usually bago magsimula start ng pagkalawang nyan.
Lagyan mo ng wax yung area na may scratch.
Kung ayaw mo lagyan ng nail polish o kaya spray paint at wala kang touch up paint edi pa pinturahan mo for your peace of mind. yun lang nga buong door pipinturahan tapos depende sa kulay baka iba itsura nyan compared to the rest of your car.
is the chip right on the door edge? in other words, it's not so big that the door panel itself has damage, right? kumbaga yung door edge tumama sa pader tapos nag-chip?
if so, here's an old bodyshop trick: simply get the touch up paint (or similar color) from a dealer or paint shop (if possible make sure they thin it out so it's more thin like nail polish and not thick like house paint).
take a pipe cleaner or cotton bud, dip it in the paint, and then run it along the edge of the door. it should cover it up nicely. i wouldn't bother with rust preventer. sayang naman pinturahan yung buong pinto for a 2mm chip.
btw, don't wax anything if you plan to paint. those two don't mix like oil and water
