Results 1 to 8 of 8
- Oct 2005
- 9
November 21st, 2005 08:27 PM #1good evening fellow tsikoteers! just want to ask kung merong member na may maintenace manual ng honda city exi 1996, or kung saan pwede maka download thanks in advance sa makakatulong
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 22nd, 2005 08:54 AM #2hondas service schedule:
W H A T W E D O
1,000 km. Preventive Maintenance Check
· Change Engine Oil and Filter · Inspect Suspension Mounting Bolts · Inspect Exhaust System · Inspect Brake Lines and Connections · Inspect Belt Tension and Conditions · Clean Air Cleaner Element · Inspect Ignition Timing and Idle Speed · Inspect Brake Fluid Level · Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer) · Inspect Belt Tension and Conditions · Inspect Compressor Clutch and Joints · Inspect Freon Gas Level (Check Sightglass For Bubbles) · Inspect Engine Cooling Lines and Connections
5,000 km., 15,000 km., 25,000 km., 35,000 km., 45,000 km., 55,000 km., 65,000 km., 75,000 km., 95,000 km., 105,000 km. Preventive Maintenance Check
· Change Engine Oil and Filter · Inspect Exhaust System · Inspect Brake Lines and Connections · Inspect Front and Rear Brakes · Inspect Fuel Tank, Fuel Lines and Connections · Clean Air Cleaner Element · Inspect Ignition Timing and Idle Speed · Inspect Brake Fluid Level · Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer) · Inspect Battery Electrolyte Level · Inspect Belt Tension and Conditions · Inspect Compressor Clutch and Joints · Inspect Condenser Of Dirts and Insects · Inspect Freon Gas Level (Check Sightglass For Bubbles) · Inspect Engine Cooling Lines and Connections · Inspect A/C System, Lines and Connections [ TOP ]
10,000 km., 30,000 km., 50,000 km., 70,000 km., 90,000 km., 110,000 km., 130,000 km., 150,000 km., 170,000 km., 190,000 km. Preventive Maintenance Check
· Change Engine Oil and Filter · Inspect Tie Rod Ends, Steering Gearbox and Boots · Inspect Suspension Mounting Bolts · Inspect Exhaust System · Inspect Brake Lines and Connections · Inspect Front and Rear Brakes · Inspect Driveshaft Boots · Inspect Fuel Tank, Fuel Lines and Connections · Inspect Belt Tension and Conditions · Clean Air Cleaner Element · Clean Spark Plugs (Replace If Necessary) · Inspect Ignition Timing and Idle Speed · Inspect Brake Fluid Level · Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer) · Inspect Battery Electrolyte Level · Inspect Compressor Clutch and Joints · Inspect Condenser Of Dirts and Insects · Inspect Freon Gas Level (Check Sightglass For Bubbles) · Inspect Engine Cooling Lines and Connections · Inspect Steering Pump, Lines and Connections · Inspect Clutch Free Play · Rotate Tires (Check Conditions, Wear And Pressure) [ TOP ]
20,000 km., 60,000 km., 100,000 km., 140,000 km., 180,000 km. Preventive Maintenance Check
· Change Engine Oil and Filter · Replace Fuel Filter (Carburator) · Inspect Tie Rod Ends, Steering Gearbox and Boots · Inspect Suspension Mounting Bolts · Inspect Exhaust System · Inspect Brake Lines and Connections · Inspect Front and Rear Brakes · Inspect Driveshaft Boots · Inspect Fuel Tank, Fuel Lines and Connections · Inspect Belt Tension and Conditions · Inspect Distributor Cap and Rotor · Replace Air Cleaner Element · Clean Spark Plugs (Replace If Necessary) · Inspect Ignition Timing and Idle Speed · Inspect Brake Fluid Level · Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer) · Inspect Battery Electrolyte Level · Inspect Compressor Clutch and Joints · Inspect Condenser Of Dirts and Insects · Inspect Freon Gas Level (Check Sightglass For Bubbles) · Inspect Engine Cooling Lines and Connections · Inspect Steering Pump, Lines and Connections · Inspect Parking Brake Adjustment · Inspect Clutch Free Play · Rotate Tires (Check Conditions, Wear And Pressure) [ TOP ]
40,000 km., 120,000 km., 200,000 km. Preventive Maintenance Check
· Change Engine Oil and Filter · Replace Transmission Oil · Replace Engine Coolant · Replace Fuel Filter (Carburator and PGM-FI) · Inspect Tie Rod Ends, Steering Gearbox and Boots · Inspect Suspension Mounting Bolts · Inspect Exhaust System · Inspect Brake Lines and Connections · Inspect Front and Rear Brakes · Inspect Driveshaft Boots · Inspect Fuel Tank, Fuel Lines and Connections · Inspect Belt Tension and Conditions · Inspect Distributor Cap and Rotor · Inspect Valve Clearance · Replace Air Cleaner Element · Replace Spark Plugs · Inspect Ignition Timing and Idle Speed · Inspect Positive Crankcase Ventilation Valve · Replace Brake Fluid · Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer) · Inspect Battery Electrolyte Level · Inspect Compressor Clutch and Joints · Inspect Condenser Of Dirts and Insects · Inspect Freon Gas Level (Check Sightglass For Bubbles) · Inspect Engine Cooling Lines and Connections · Inspect Steering Pump, Lines and Connections · Inspect Parking Brake Adjustment · Inspect Clutch Free Play · Rotate Tires (Check Conditions, Wear And Pressure) [ TOP ]
80,000 km., 160,000 km. Preventive Maintenance Check
· Change Engine Oil and Filter · Replace Transmission Oil · Replace Engine Coolant · Replace Fuel Filter (Carburator and PGM-FI) · Inspect Tie Rod Ends, Steering Gearbox and Boots · Inspect Suspension Mounting Bolts · Inspect Exhaust System · Inspect Brake Lines and Connections · Inspect Front and Rear Brakes · Inspect Driveshaft Boots · Inspect Fuel Tank, Fuel Lines and Connections · Inspect Belt Tension and Conditions · Inspect Water Pump · Replace Timing Belt · Inspect Distributor Cap and Rotor · Inspect Valve Clearance · Replace Air Cleaner Element · Replace Spark Plugs · Inspect Ignition Timing and Idle Speed · Inspect Positive Crankcase Ventilation Valve · Replace Brake Fluid · Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer) · Inspect Battery Electrolyte Level · Inspect Compressor Clutch and Joints · Inspect Condenser Of Dirts and Insects · Inspect Freon Gas Level (Check Sightglass For Bubbles) · Inspect Engine Cooling Lines and Connections · Inspect Steering Pump, Lines and Connections · Inspect Parking Brake Adjustment · Inspect Clutch Free Play · Rotate Tires (Check Conditions, Wear And Pressure)
November 22nd, 2005 02:10 PM #4
*speedyfix: medyo ot, but, diba taga LP ka? ilang kms ulit yung timing belt change ng pizza? tsaka gumagawa kayo neto diba?
Toyota is my choice
- Aug 2005
- 2,063
November 25th, 2005 08:27 AM #6sa toyota din po. if pwde.. if okey lng. maintenance overview lng po.. help. thnx!
November 25th, 2005 03:42 PM #7Originally Posted by happy_gilmore
i think though not sure pero 80k yata ang timing belt?
- Nov 2003
- 3,849
November 29th, 2005 12:45 PM #8yup. we're in santolan
well for the most part, these service intervals can be used for all kinds of cars. the 40 and 80k replacement of all fluids for example is followed for most makes and brands. timing belt is at 70-80k kms, etc etc etc.
use that as a guide and just change it accordingly to what has or has not yet been done to your car.
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
