Hi! Tanong ko lang po kung magkano usually ang break pads? ung original? thanks!![COLOR=Teal][SIZE=3][/SIZE]
roxy_gurl, ano ba ride mo? orig brake pads kc costs from 1500 to 3500 Php. depende sa ride yan.
after market brake pads are better than original or manufacturer's. They usually buy from the lowest bidder. Its your brake, so don't go cheap. Your life is depending on that little pad stopping a hunk of metal weighing more than a ton.
bilin mo yung hawk pads para oks. o kaya e raybestos. wag OEM kasi hindi maganda ang pads nila and madaling maupod
Mahal ang OEM. Bendix ang gamit ko. Around Php 500.00 nga ba?![]()
AFAIK, meron kina GlennSter sa G&S (92 Kamias Road, Q.C.). Not the cheapest but reasonable na din.
if you're going to buy original, you might as well get performance pads like tanabe... much better in the long run and lakas pa preno![]()
Speedy Fix, may replacement ba ang Honda Civic 2000 brake pad. I'm using the OEM eversince eh. it price 2.3K yata. Due for replacement na yun pad ko.
halos lahat na ng cars may aftermarket na brake pads, Ok ang bendix na brand pre.
bendix din gamit namin para sa bighorn. 1k sa front and 1k din sa rear.
