Results 1 to 2 of 2
- Aug 2003
- 9,720
November 9th, 2005 09:50 AM #1ano ung usual ways to minimize it? is it just a matter of adding more engine mounts or adjusting the air/fuel mix?
- Sep 2005
- 40
November 10th, 2005 09:46 AM #2Originally Posted by badkuk
Even Pmax pressure in all cylinder while engine running will reduce torsional vibration of the engine.Ibig ko sabihin,kelangan equal combustion pressure sa lahat ng cylinder,so maraming kang iconsider jan such as inj nozzles,inj pressure,proper seating of intake and exhaust valves,loose compresion etc.
alternative is to increase rpm above the bared point of the engine or replace your engine ruber cushion or suport,baka may crack na un rubber.
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
