Results 1 to 10 of 12
Tsikot Member Rank 3
- Mar 2003
- 637
March 8th, 2004 05:48 PM #1sa tingin niyo may kulang ba na parte dito sa air intake ng van ko or ganito lang talaga ito? meron pa kayang naka konekta dito sa tubo na ito? :confused:
- Dec 2002
- 551
March 8th, 2004 05:58 PM #2sa tingin ko sir parang kulang po siya. I think it should make a turn to the hole in the left side so that it can suck in cold air from the outside
BTW what kind of a van do you have sir : )
- Dec 2002
- 551
March 8th, 2004 06:02 PM #3sa tingin ko sir parang kulang po siya. I think it should make a turn to the hole in the left side so that it can suck in cold air from the outside
- Mar 2003
- 637
March 9th, 2004 12:27 AM #5
Yung sa Besta ko ganyan din lang. For sure hindi kulang yun kasi pare-pareho sila ng ibang units.
Ewan ko lang itong sa Grace.
March 9th, 2004 08:10 AM #6
Intake yata yan going to the filter. Mukhang hindi naman kulang. Yan din kasi ang position ang location ng air intake ng pick-up ko eh.
- Mar 2003
- 637
March 9th, 2004 10:58 AM #8thanks sa mga nag reply kasi kung titignan parang kulang kaya tinanong ko dito.
- Jan 1970
- 396
March 11th, 2004 01:48 PM #9usually may mga pipe extension lang yan to direct the flow of air from the front or any convenient location..
March 11th, 2004 05:30 PM #10
that pipe was intended to be connected dun sa side grill (near the door) to suck in air. but due to floods the manufacturers opted to just cut it and just let it suck air in the engine compartment, just to prevent it from sucking in water incase the driver in bold enough to drive thru flood.
I have a digital gauge that measures, among other things, engine coolant temp. 90% of the time,...
