Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Mar 2003
    sa tingin niyo may kulang ba na parte dito sa air intake ng van ko or ganito lang talaga ito? meron pa kayang naka konekta dito sa tubo na ito? :confused:
    Dec 2002
    sa tingin ko sir parang kulang po siya. I think it should make a turn to the hole in the left side so that it can suck in cold air from the outside BTW what kind of a van do you have sir : )
    Dec 2002
    Mar 2003
    hyundai grace
    Yung sa Besta ko ganyan din lang. For sure hindi kulang yun kasi pare-pareho sila ng ibang units.
    Ewan ko lang itong sa Grace.
    Intake yata yan going to the filter. Mukhang hindi naman kulang. Yan din kasi ang position ang location ng air intake ng pick-up ko eh.
    opportunity to install a cold air intake tube?
    Mar 2003
    thanks sa mga nag reply kasi kung titignan parang kulang kaya tinanong ko dito.
    Jan 1970
    usually may mga pipe extension lang yan to direct the flow of air from the front or any convenient location..
    Jan 2003
    that pipe was intended to be connected dun sa side grill (near the door) to suck in air. but due to floods the manufacturers opted to just cut it and just let it suck air in the engine compartment, just to prevent it from sucking in water incase the driver in bold enough to drive thru flood.
may kulang ba dito?
