Results 1 to 10 of 13
- Dec 2006
- 25
May 8th, 2007 02:44 PM #1dear all,
gud pm....
any feedback po sa price nitong map sensor ( 01 civic vti )?
if di po ito replace, ano impact sa engine ?
tnx in advance.
- Dec 2006
- 25
May 8th, 2007 06:44 PM #3
Don't have much knowledge about Hondas so I suggest you call up Speedyfix, search mo dito yung mga post nya, nandun sa signature nya yung telephone number ng shop nya.
Impact on the engine would probably be poor performance and poor fuel consumption.
May 8th, 2007 11:06 PM #4
I don't have any idea on the price on the MAP sensor but this measures the air pressure (airflow) coming through the intake of the engine and sends a signal to the ECU for the proper calibrations on the a/f mixture and combustion. A busted MAP sensor (you sure it's really this?) can cause erratic engine idling amongst some.
On other makes (like Nissan and Mitsu), the counterpart of the MAP sensor is the MAF (Mass Air Flow) sensor. These are sensitive buggers and if they're dirty, corroded (their wires), or miscalibrated, they can give you poor engine performance and erratic idling gremlins.Last edited by vinj; May 8th, 2007 at 11:09 PM.
May 9th, 2007 07:17 AM #5
It won't cause erratic idling; the error almost always occurs one way or another, not fluctuating. It will cause your engine to run either rich or lean. Essentially, either a loss in fuel efficiency or a loss in power.
BANNED BANNED BANNED
- 3,790
May 9th, 2007 09:05 AM #6MAF (mass airflow sensor yata) measures the air getting into the car and mixing with the fuel... a dirty MAF sensor will hamper your car from reaching its top speed (due to the wrong a/f mixture perhaps) ... an as mentioned above loss in fuel efficiency.
- Dec 2006
- 25
May 9th, 2007 05:39 PM #7tnx po dun sa nag reply.
another Question: will it (map sensor) damage the computer box if not replace ASAP?
May 9th, 2007 06:09 PM #8
It will not. Unless your wires are grounded and sends a signal to your ECU in excess of 5volts.
May 9th, 2007 08:27 PM #9
- Dec 2006
- 25
May 10th, 2007 01:25 PM #10tnx mga sir....
anyway, any inputs on price?
> OEM or slightly used......
aside from Speedyfix,san pa po pede makabili nito or maka-order..... ( last na pong option yung casa kasi medyo expensivepo )
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
