Results 1 to 10 of 24
June 10th, 2007 07:52 PM #1
Pag naka-ON ang AC at headlight nawawala ang busina pero pag naka-OFF ang headlight at AC malakas naman ang busina.
Yung battery 1 year 1 month pa lang, Motolite Enduro mintenance free.
June 11th, 2007 04:36 AM #2
check mo muna battery connection. yun terminal paki tighten yun mga clamps. pati yun ground piggy wire papunta sa chassis check mo na din. pero malamang sa terminal lang yan.
June 11th, 2007 06:44 AM #3
Ayos naman mga terminals nilinis ko talaga nung isang araw kasi tumirik nung friday ang sabi ng mekaniko starter lang so pinagawa ko yung starter nagpa-charge na din ako ng battery. Kagabi ko lang napansin na nawawala yung busina nung galing na kami ng simbahan.
Toyota is my choice
- Aug 2005
- 2,063
DIY to death!
- Jan 2003
- 451
June 11th, 2007 09:06 AM #5Alternator, voltage regulator, grounded somewhere, battery defective (one of your suspects). Madaming pwede e.
Tsikot Member Rank 4
- Jun 2006
- 2,605
June 11th, 2007 09:14 AM #6You can test your battery charge using a volt meter. It should be over 12volts with the engine off. If engine is running you should get around 13.8 volts.
June 11th, 2007 12:19 PM #7
ganyan din prob ko,e.. pumupuyok ang busina kapag naka aircon at ilaw at engine idle speed...pero mukang battery na ang prob ko, kumakarga, pero di nagreretain ng charge yung battery ko.. wal naman naka-on/shorted, kasi pag inaalis ko, di nag-sspark yung terminal,e.. plus mahina ang 70AH stock output sa van ko,kasi sa ICE ko din,e..papalit ko ng higher output alternator pag may nakuhang masmalaking pwedeng mapagkasya sa engine ko...110AH nga sana para walang bitin! pag mahin pa naman ang betterya, hirap or hindi sisipa ang starter!
hope maka kita mo prob mo syu!
June 11th, 2007 03:09 PM #8
June 11th, 2007 09:45 PM #9
- Jan 2003
- 2,979
June 12th, 2007 11:53 AM #10same battery ba yun pinalit mo? (2sm or 3 sm) check mo alternator baka di na nagkakarga. malamang yan grounded yun wiring ng busina mo. pare-wire mo yun busina.
add lang ako ng question. I have seen pajero's na may nakalagay na 2 2sm batteries, meron din single 3 sm. ano ba talaga ang kailangan i-consider kung 2sm or 3sm or other type of batteries ang dapat ilagay?
[QUOTE=ice15;3387274]medyo disappointing itong Sealion 5 No front sensor either Manual Seats...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
